on 03-07-2023 12:23 PM
Hi ... does anybody know what the DHCP range of addresses is issued by the DHCP server of the dongle? I could do with starting and ending addresses, knowing that they be of the foirm: 192.168.1.X to .Y
Alternatively , is it possible to change the DHCP server parametrs to control the range and addresses?
Thanks in advance - sajax
03-07-2023 01:01 PM - edited 03-07-2023 01:03 PM
@sajax : The DHCP of the 4GEE WiFi router & its range is not available to you. You can view the local IPs assigned to your devices under Status > Connected Devices.
on 03-07-2023 01:27 PM
That's no good... I have devices that don't accept DHCP addresses that i intend to use but are currently using addresses in the range that looks like it may be issued by the dongle. It must be possible to find out what the range of addressdes is that the dongle issues?
on 03-07-2023 01:34 PM
No, I don't like it either. I never use the 4GEE WiFi, preferring the EE Osprey, which does give you control of its DHCP range.
on 03-07-2023 01:50 PM
That is completely ridiculous... luckily the unit is brand new and going back... I can't use it if i can't even get the DHCP range what are BT/EE playing at? I'd actually prefer to change the local ip address and the range such that I then don't have to change any of the fixed addresses I already have inserted into the network devices...
Many thanks for your somewhat limited help but very revealing information...
Regards sajaxs
on 03-07-2023 01:58 PM
