on 23-04-2023 08:35 AM
good morning
My 4G router is constantly buffering every time I’m streaming anything can anyone help
thanks
on 23-04-2023 09:18 AM
Do you have an EE mobile, does it have similar problems when watching videos?
Does this vary depending on time of day/day of week etc?
on 23-04-2023 09:33 AM
Hi thanks for the response, no I don’t have a mobile. It can be working perfectly for ages then it’s hours of buffering. but listening to music on Alexa is fine all day. Did a speed test and it’s perfect, I have unlimited downloads I don’t know what’s else to do tried all the switching off for a while and switching it back on still doesn’t it.
cheers
on 23-04-2023 10:38 AM
Hi @Jimmyj7700
Thanks for coming here.
Have you checked the EE Coverage Checker to see if there are any reported problems in the area when this happens?
If you enter the postcode and select 'Check Status' this will show any reported problems. If nothing is showing you can report this to us and our network team will get this looked into and keep you updated.
on 23-04-2023 11:34 AM
Hi thanks I have checked and there seems to be no problem. So how do I contact yous directly
thanks
on 23-04-2023 11:37 AM
Hi @Jimmyj7700
You can call us on 07953 966 150 and our tech gurus will get this looked into for you.
on 23-04-2023 01:05 PM
What does "it's perfect" mean? What speeds are you achieving?
