21-11-2026 04:43 PM
So my router is conect and I have WiFi and everything is working smoothly
But I bought an extender,switch it on another showing green light every 5 seconds. Green light is on about 10 seconds and gone about 5/6
I've try to reset the device direct types and still noting.Green light only
It doesn't respond on reset button 😒
Loking for any advice
21-11-2026 05:29 PM - edited 21-11-2026 05:31 PM
@IvayloRibarov They say that it is best to switch the EE Hub off along with the EE Extender, start the Extender up first, give it five minutes to set it's self up, bring the Hub back on and see what happens then. Going to link the EE Pinned post. Use the info supplied from Profile Closed you will see that, seems to be the most comprehensive for getting it done.
Top Tips for pairing your WiFi Extenders to the Smart Hub 7 Pro - The EE Community
23-11-2026 10:56 AM
I know the dril
But the isue is when swiched on is already on green light.The reset buton dont change anything,even presing it for 20 sec.Its just frozen on Green light,blinking every 5/6sec
23-11-2026 11:16 AM
@IvayloRibarov If you got it from EE then call them up and let them know what is happening to it, they will make the required decision to what is the next step.
23-11-2026 08:04 PM
