4G mini wifi router no internet access to my devices
ADR48
My 4G mini wifi portable router is not allowing wifi access to any of my devices why?
13 REPLIES 13
James_B
EE Community Manager
Hi @ADR48,
Are you unable to connect your devices to your 4GEE mini's WiFi network, or do they have no internet connection once connected?
I can connect my devices to the network but it will not give me internet access
James_B
Hi @ADR48,
Are you using a pay monthly or pay as you go plan?
Have you just purchased it?
Does My EE show you have an activate data allowance?
Pay as you ago was purchased a couple of weeks ago  and all was fine and then suddenly stopped giving access. I still have plenty of credit on my account that I have bought
James_B
Hi @ADR48,
Did My EE show you had an active data add-on?
If you just have credit, you may just need to use it to purchase an add-on via your My EE account.
Yes i have an active data add on of around 18gb purchased for the month, have been using this device for a long time with no issues only now there is a problem
James_B
Hi @ADR48,
Are you in the UK?
If you are, does the Network Status Checker report any problems in your area?
I ma in Europe at present not in the UK as I said it was all good until a few days a go and then just stopped giving access
James_B
Hi @ADR48,
Sorry, you can no longer use your UK allowances without a roaming add-on in the EU.
To purchase a roaming add-on, please log in to My EE.
