on 28-10-2022 03:29 PM
Hi, 4G Wifi Mini, has been working fine, now won't connect to the internet. Signal light stays red. Tried connecting via PC, still can't check for firmware updates. It's less than a year old...any idea's!
Solved! Go to Solution.
on 28-10-2022 04:10 PM
Hi Jon, fault seems to be solved…..the SIM card had locked out. I put the SIM in another phone and tried calling voice mail, had to press 1 to re-activate the SIM. Wi-Fi mini is now working again!
Thanks for your suggestion 👍
on 28-10-2022 03:48 PM
Thanks for coming here, @Squeaky76.
Have you tried restarting the device?
If this doesn't work, can you try resetting it using the reset button?
Jon
on 29-10-2022 08:26 AM
Thanks for letting us know, @Squeaky76 🙂
on 21-07-2024 01:10 PM
I have tried the same thing, but it's not working.
on 21-07-2024 02:01 PM
Hi @contactjayd,
What problems are you experiencing with your 4GEE WiFi device?
on 22-07-2024 12:53 AM
Hi James, I recently got a mifi from EE due to relocation. I paid a full fiber 900. And my mifi sim is not activated. And I have been DD for the services. This is absolutely diabolical.😭😭😭😭
on 22-07-2024 08:21 AM
Hi @contactjayd
Are you able to try the WiFi SIM card in another device or mobile to see if this works for you?
