on 21-07-2022 10:26 AM
My 4G EE router is not working. None of my devices can detect it starting from this morning. I have been using it just for less than 2 days and it was workinng fine. Problems I saw for now -
1. All 4 green lights are on but none of my devices can detect the router.
2. Try switch off and on does not solve the problem. Even I switch on, the 4 lights immeditely on and none of them blinks
3. Try the reboot button but the router does not seem to reboot no matter how long I press it. All 4 green lights remains on.
I am on unlimited 4G plan btw.
on 21-07-2022 12:35 PM
Hi @TimTan_2017
Welcome to the community.
Do you know if anyone else in your area is having problems with their data service? Could you check our network status checker to see if there are any maintenance works in your area please?
on 21-07-2022 12:39 PM
Hi @TimTan_2017
Try resetting the device via the reset button.
on 21-07-2022 12:49 PM
Hi Chris, I don't know whether others experience data service issue but the sim card is working fine in a mobile device. The problem is with the router based on what I saw. You can refer to my first post which describes the problem.
on 21-07-2022 12:51 PM
Hi @Northerner ,
The reset button does not work for me. No matter how long I press the reset button, the router does not seem to reboot. 4 green lights remain on. No blinks, no sign of rebooting.
on 21-07-2022 03:01 PM
Hi @TimTan_2017.
Are you pressing and holding the reset button for around 15 seconds?
Is there anything blocking the reset button?
Jon
