on 21-07-2022 06:00 PM
Hi
I'm having issues getting Broadband installed in my property so I bought a 4GEE Wifi Mini.
As you can imagine using it for home use means the data disappears quickly!
My question is, if I bought a Data SIM from EE with Unlimited Data for 1 Month would that work in the 4GEE Wifi Mini, essentially giving me Unlimited Data for a month?
Hope this makes sense.
Thank you
Scott
Solved! Go to Solution.
on 21-07-2022 06:10 PM
Hi @Scott19771
EE don't sell unlimited plans. Their unlimited plans are 600GB. (Read the T&C)
If that meets your needs then yes it will meet your needs.
Hi @Scott19771
