Xbox nat type strict on wireless router
Tbriggs_11
Hi I recently purchased the smart hub 3 wireless router and when I go to connect my Xbox it’s says UPnP unavailable , it is enable on my settings for the hub , would anyone have any solutions to fix this problem I’ve seen things about port forwarding but I don’t have a good understanding of it
Is this a fixed Home BB router or a mobile router?
Tbriggs_11
Hi
it is a mobile router
Colesey
Run the ‘test NAT type’ test in the Xbox network settings a couple of times, your Nat will change to open.
Full Fibre Gigabit
Smart Hub Pro
Hi
ive tried this solution and it is still saying my NAT type is strict you sure this is the the solution for a mobile router
Hi
yes it is a mobile 5G router , I’ve been reading about it online and says port forwarding is a solution would you agree this would work
