29-08-2025 08:09 PM
Whenever I turn connect my Meta Quest 3 to the Wi-Fi, the ping for all devices Including the headset spikes up to over 1000ms making the headset unusable for Online Play, I have an EE Smart Hub Plus and sometimes it doesn't happen, however randomly it will kick in and i can no longer use it or any other device in my home until i disconnect it from the Wi-Fi. I have tried factory resetting my headset or even using a Meta Quest 2 and the issue continued while using that, I have also tried using the "Compatible Wifi" Option on my Hub and connect my Meta headset to that but the issue still happened.
30-08-2025 08:30 AM
Hi @Horizon2
How far away from the router are you when this issue occurs.
Is this a recent issue.
