Something went wrong
Brandon998
I’m wanting to add the PlayStation 5 slim console 24 month bundle with £100 ee gamecard been trying for over a week and as soon as I press checkout it loads up and then says something went wrong come back later just wondering if there’s an issue with the website
16 REPLIES 16
Christopher_G
Hi @Brandon998
Welcome to the community.
Could you try doing this on a different device or browser please? Just to see if the same thing happens.
Yes ive tried on my phone as well as my partner and it’s saying something
went wrong try again later
Christopher_G
Could you try when not connected to WiFi please, @Brandon998? Is it still the same?
IMG_0321.pngStill doesn’t work got the same problem tried laptop,iPad and 2 phone still won’t work
Christopher_G
OK, thanks for trying @Brandon998
I recommend speaking with our Mobile Care team so they can check your eligibility and add it manually for you.
How do I get into contact I’ve pressed on the the mobile care team just takes me to a dashboard
Christopher_G
If you dial 150 from your EE phone, you'll get through, @Brandon998 .
The dashboard gives you contact options of you're not calling from an EE phone.
Okay cheers Christopher thanks for your help
