Meta quest 3 bundle
Connorgeddes
Recently got the meta quest 3 bundle with 24 months of gamepass and have no details of hot to redeem it
Alex_H
Hi @Connorgeddes,
Welcome to the EE Community
If you visit ee.co.uk/xbox and enter the number you added the Meta quest 3 bundle to, confirm the PIN sent via text and you should then see the Game pass there to activate.
Let us know how you get on 🙂
Alex
Alex_H
Hi @Connorgeddes,
Alex
Hi it says there is nothing to activate
Alex_H
@Connorgeddes  Just to confirm you have added the bundle to be paid with your monthly EE mobile bill?
Do you have multiple numbers on your account, as the number you enter does need to be the one the bundle has been added to.
Also make sure you have no VPN in use when going to the activation page, and if possible access it on your mobile data connection rather than a Wi-Fi connection.
If it is still saying there is nothing to activate once going to ee.co.uk/xbox then you will need to give us a call on 150 from your EE mobile so our team can check to make sure the Xbox part of the bundle has deployed to your number and if not manually add it so that you can then activate it using the link.
Alex
nattycakes13
Same and I've called them noo help feel like been conned with it and my kids upset as was for Xmas
