on 15-01-2024 06:58 PM
How do i get the best when it comes to hotspots and connecting my xbox to play online. It works but some games a bit laggy and i always have strict nat type what can I do to make it better?
on 16-01-2024 12:20 AM
You are probably finding yourself up against a limitation of EE's mobile network. The EE mobile network uses Carrier Grade NAT (CGNAT) resulting in a double NAT, which games consoles often object to, which means you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net & therefore your LAN cannot be addressed from outside for unsolicited accesses. This is unlike fixed BB.
If this occurs there is nowt you can do to avoid it.
IMHO EE the mobile network is not really suitable for gaming.
