Fc25 on ps5 connection fault
Jef0
Hi don't know if anyone else is having connection issues on ultimate team freezing or not connecting have had this problem for about 2weeks and only happening on ee or bt hubs have contacted fine on sky hub and post office any help or advice thanks jeff
6 REPLIES 6
Peter_W
Good morning @Jef0.
Welcome to the EE Community 😊
Are you noticing this same issue with other games, or just FC25?
How often would you say this is happening too?
Peter
Just fc25 been about a 2weeks now at moment that bad am using next doors po
and working better than ever thanks jef0
Peter_W
Thanks @Jef0, have you had a chance to give this a try on your EE connection recently?
I'd recommend running a check on your line so we can be sure everything is as it should be at your end, then giving this another try.
Peter
Will do later today as I have squad battle games to finish and already lose
6 because of lose of connection thanks jef0
Peter_W
Thanks @Jef0, please keep us posted on how you get on.
Peter
Hi seams to be better at the moment hopefully it keeps going will keep
trying it for rest of the week thanks for the fast response
Thank you jef0
