Pin
Jpieniazek
Hi
i have a problem with my EE app im trying to log in and I need a pin? I don't have any and don't know where to look
@Jpieniazek  if this is asking you to enter a pin then this  pin is something that you previously set up on the My EE app. If you do not remember that pin then the best way around this will be to delete the app and reinstall it and set it up from scratch and remember the pin number that you give it..
9 REPLIES 9
Hi, how can you delete the app on the EE box?
Katie_J
Hello @Mars7.
What App are you looking to delete from your EE TV Box?
Katie
I’ve tried to delete the app but it comes up again what should I do?
Rach_H
Hi @Pedro7,
If you enter the wrong PIN into the app then this will take you to the main sign-on page, which should allow you to log in with your email address and password, or reset your password if you don't know what this is.
Rach
Danwia1954
Ja też nie mogę się zalogować bo potrzebny kod PIN ja w ogóle nie wiem jaki jest kod PIN a nowa rejestracja nie wchodzi grę w ogóle nie mogę wejść
Katie_J
Hello @Danwia1954.
Thanks for coming here.
If you are trying to access the EE app and do not know your EE PIN please try deleting the EE app and re-installing.
You should be able to log in using your EE password.
Katie
KamoKamo17
I forgot my pin number from ee app
Ali_A
@KamoKamo17
If you have forgotten your App PIN, the easiest way to reset it is to uninstall the app and then reinstall it. It will ask you to set up a new PIN.
Ali
