25-02-2026
09:25 AM
- last edited on
25-02-2026
09:28 AM
kh-shaikh
I am unable to see anything about my mobile contract informatiom, no usage, no bills nothing.
Cant link it as already says its limked. Please help
[Mod edit: Title edited]
25-02-2026 12:32 PM
Hi @Jade220
Thanks for reaching out here on the community.
Can you view your contract information when you sign in via the website rather than the app?
Please make sure your App is on the latest software, if it is already up to date then you could try un-installing the app and re-installing it to see if that works.
If you are still unable to view your information after trying the above steps, I would recommend Contacting our guides, they will be able to take a look into this for you.
Ritu
25-02-2026 09:21 AM
I am having the same problem cant see anything
25-02-2026 12:32 PM
Hi @Jade220
Ritu
09-03-2026 10:53 AM
Have never been able to see my contract details either on the app or on the webpage.
This is the message currently on the webpage, it was the same message last month:
We can’t show your plan right now. Refresh or come back later when we’ve fixed things.
09-03-2026 01:04 PM
Hi @ATCO2
It sounds like there may be an issue with your online access.
Please give our Customer Service team on 150 from your handset where a guide will be able to investigate the error you're experiencing.
They may need to raise a ticket to the technical team, to resolve the glitches you have faced. Or alternatively remove your online access completely allowing you to re-register with a fresh access.
Once this has been resolved you'll be able to access your details, plans and contract as expected.
Ali
