06-11-2026 07:04 PM
Hi
i have an iPhone 13pro max. It had a battery problem. Long story short. I transferred the phone to another iPhone went on holiday and came back. I was able to transfer the profile back onto iPhone but now can’t make calls or text. I can use it over WiFi.
How do I get it to work again? I can’t believe how hard it is to contact EE!
06-11-2026 09:31 PM
@SimonC74 have you put the sim back in the iPhone ? Or are you using eSIM ? When setting back up on the 13 P/M did you select eSIM but you are using a physical sim ?
To speak with customer support select option 2 at the start then the closest option to your issue. If you keep selecting option one it’s all automated so you’ll not speak with anyone.
06-11-2026 09:35 PM
07-11-2026 11:38 AM
07-11-2026 11:57 AM
Hi
no I haven’t spoken to anyone in technical department. If you go contact us it avoids any mention of speaking to any sort of human being where possible. It sent me to the community here instead
it is sadly the way of customer service these days. Do the bare minimum and see how it sticks, then do less.
07-11-2026 12:11 PM
@SimonC74 , have you done what @Chris_B , has suggested? Ring customer service and press option 2 , you can then speak to someone, or text PHONE or GUIDE to 66033 and someone will be able to help.
07-11-2026 05:38 PM
No I haven’t spoken to anyone.
I was expecting some sort of answer on here. But the talk is all about process and no help. I am only surmise you work for EE.
I reset network settings in the iPhone. The phone got stuck on reboot so I did a hard reboot on the iPhone it allowed phone number to set as primary which it wasn’t before. Still can’t make any calls or use network data.
anyone want to offer any technical solutions?
07-11-2026 09:05 PM
@SimonC74 does the eSIM still work on the other device ? If it doesn’t you have to call customer support ( select option 2 ) then select the closest option to your issue. Your eSim has been wiped if it doesn’t work on the other device, so it needs to be sorted by you calling customer support to activate it the other device.
07-11-2026 09:56 PM
The other phone is back to its original user and is all fine. It’s the original phone which we are trying to get back up and running which isn’t working.
we restarted the phone from its back up and downloaded the eSIM back onto the original iPhone. It’s not been the same since. I reset the network settings and it worked for a very short time. Now now calls no data. Only WiFi.
Maybe I’m physic but I am guessing someone is going to tell me to call and press option 2?? Quite the technical community this one. Hey maybe I should turn it off and on again!
