03-05-2025 09:56 AM
I am aware a number of EE users in portugal have had an issue making calls after the power outage 5 days ago. My wife and I still cannot make calls (including WiFi calls)
How do we fix?
03-05-2025 09:22 AM
I’m in Portugal and since the power outage I can’t make any phone calls…WhatsApp calls are fine, email, internet and everything else is fine but I can’t make a “normal” phone call…any else had the same issue/how did you resolve?
TIA
03-05-2025 09:49 AM
If there was an issue with the local network then you'll need to wait until that network is fixed. This is outside of EE control.
Try periodically restarting your device.
03-05-2025 10:46 AM
Standard troubleshooting, and several other threads reporting, have you tried manually cycling through the various local networks?
Are your symptoms the same on each one?
03-05-2025 10:55 AM
Can not call EE because I can not make calls no more after the electricity cut... Who knows what is going on ,?
03-05-2025 11:02 AM
Can't make phone calls after the power cut .. really bad.. can not even call EE
03-05-2025 11:05 AM
@Theo2411 who knows what’s going on with what ?
If the local network has been affected by power outages this will also include cellular masts as they need power to operate so your device doesn’t connect to a mast as there is no cellular signal to connect too.
03-05-2025 11:07 AM
Hi . Did you find out why there is no roaming... I have same problem.. can't call EE and being stuck in the mountains of Portugal without phone / only what's app
03-05-2025 11:09 AM
Power cuts to the access network cause a total loss of coverage.
If users can send & receive texts, and/or use mobile data, and/or receive calls, the issue is not coverage related.
03-05-2025 11:46 AM
We have 9 lines some currently roaming some not noone can make normal calls or texts
