plus net to ee broadband with home phone
rmgl
Plusnet has transferred me over to ee broadband that has resulted in my home phone now being connected to the new ee router ...but now I've lost the use of my  extension phone !  how is this progress . any help on how to get the extension phone linked to the one phone socket allowed by the router please ?
@rmgl : You need a ATA adapter plugged into a mains socket remote from the router. It communicates with the router by DECT. See Set up and use a Digital Home Phone Adapter
Jones01
Skilled Contributor
Skilled Contributor
If you've got full fibre you can use the old BT master socket to feed your extension(s). It's best to cut the redundant BT copper cable where it comes into your house first, being careful not to short out the cable internal wires.
Then connect the phone socket on the router to the BT master socket and your extension sockets should work as they did before.
If you want a phone connected to the router socket as well, you'll need to use a BT double phone socket adapter.
FoxRadio
Skilled Contributor
Skilled Contributor
@rmgl  In the email I received from EE telling me when my transfer date from Plusnet would be, there was a bit about how to connect a phone that wasn't near the hub. It was for a free digital voice adapter. You simply had to  text ADAPTER to 66033. Did you not receive such an email?
I received my adapter within a few days.
