cant make outgoing calls on digital phone . Can receive calls no problem.
andrew444
I think its something to do with either call features/alarm/accessibility or settings. Anyone with any ideas please.
1 ACCEPTED SOLUTION
Community Hero
Community Hero
@andrew444 Is it a new service ie just moved onto the new DV system?
Community Hero
Community Hero
No its not a new service. I've had these 4 digital voice phones for over eighteen months now and at the moment cant make out going calls as it says its call barred from making those calls. But I can receive calls on the phones. It is a little bit frustrating at the moment.
@andrew444 Have copied the help link below for you. See if it can get you out of the call barring issue.
Using Your Digital Home Phone Features | Home Phone Help | EE
