No Phone Access- Power Outage
BevanCR
Has any one like us had a power outage which affected their mobile and digital phone line and needed to make a 999 call ? How did you do this please?
14 REPLIES 14
Mustrum
@BevanCR    so you have two ways to think about the problem.
On the broadband side, if set up properly a battery backup system will keep your router and ONT if you have one powered up during a power cut. Either the exchange or the green cabinet down the road also has battery backup so your internet will keep going for as long as the batteries last. Plugging your phone into the router if you have digital voice will mean you can make calls, or use you mobile for WiFi calling if you have a suitable device.
Mobile phone masts also have battery backup, so that should also keep a signal to enable you to make calls.
So between two ways you can make your 999 calls for a number of hours after a local power outage.
The extent of BBU on radio sites varies greatly, there is no hard or fast rule.
Yeah, it is the same in the green cabinets, but the exchanges have bigger batteries and diesel generators for those on full fibre.
Thank you for that information I do appreciate it
Sent from Outlook for Android<>
Thank you for the information and your time I do appreciate it
