on 30-07-2025 03:02 PM
Has any one like us had a power outage which affected their mobile and digital phone line and needed to make a 999 call ? How did you do this please?
on 30-07-2025 03:17 PM
Buy a battery back-up.
on 30-07-2025 04:03 PM
Good afternoon @BevanCR.
Welcome to the EE Community.
I can totally appreciate your concern around losing service in the event of a power outage, and would hate to think this has left you in a vulnerable position.
As @XRaySpeX has mentioned here, we provide the option of battery backups for customers in areas prone to power cuts or using equipment like Telecare alarms.
If you check out our help page here, this gives you more information on how these works, along with the details for how to contact our team to query this as an option.
Peter
on 30-07-2025 05:51 PM
Hi @BevanCR
Mobile phones will connect to any network when you need to call 999.
on 30-07-2025 10:33 PM
on 30-07-2025 10:35 PM
on 30-07-2025 10:39 PM
Mains power outages are one of the scenarios that are known to be problematic in the migration to IP-based telephony.
However, your query was how this is addressed for emergency calls & homecare-alarms - there are some mitigations in-place to cover these. Outbound calls to 999/112 have been potentially possible on a network other than your home one, since several years now.
on 30-07-2025 10:40 PM
on 30-07-2025 10:42 PM
on 30-07-2025 10:45 PM
If you are in a location where only EE service is available, and either that site is affected by a loss-of-service or your home location is, then evidently you will not be able to use mobile service.
FYI you have a short time after posting to edit, avoiding the need for multiple short replies. It looks like you're using the email reply function instead.
