Feature Request: Allow Importing of Contacts from Mobile Phone
Kncowans
Hello all
I recently had all of My remaining Services Moved from BT to EE, as a result of this I have now been Moved onto Digital Voice.
I have the Advanced Digital Home Phone and would like to request that the ability to Import Contacts from a Mobile Phone (EE) be added.
This would allow the Home Phone and Mobile Phone to have Access to the same Contacts.
Personally, I use Microsoft Outlook on both Desktop and Mobile and My Contacts are Stored on My Microsoft Account.
Being able to Sync, or, Export the Contacts on the Mobile Phone to a VCF File and then Import said File into the Advanced Digital Home Phone would be a Huge Help.
Afterall, everything is being Connected so why not the Contacts List?
Kevin
Maestro
Maestro
@Kncowans Feature is currently not available as far as aware, you could confirm by login to your router just checked as you do not say which Type/Version you have, so details will be printed somewhere. Was supported on the BT smarthub2 and guide info available on the BT Forum if you need. HTH
