Essential Cordless Phones
JoRo1948
I originally subscribed to BT.  When I changed to HD Voice, the digital landline, I received two BT Essential Cordless phones.  These have worked well,  but lately  if I make a call and then press the button for speaker the display shows the BT logo and then the words "Synchronising handset data".  Shortly after this the call is dropped.
This happens with both handsets.  I have no idea why it is happening or how I can stop it.
Any advice will be gratefully received.
JoRo1948
Thank you @Peter_W for replying.
Both handsets are paired and have been working well for over 12  months.
After I posted the original query I continued searching online and ended up back on the BT community website (which is where I had begun my search).  I eventually found a couple of posts which referred to the problem and suggested the batteries in the handsets were not holding their charge very well.  Apparently, when the speaker button is pressed, the demand for additional current cannot be supplied and causes the call to drop and the handset to attempt to synchronise with the base. The original batteries supplied with the handsets looked cheap and rather old and so this seemed a reasonable explanation.  Mr Amazon kindly supplied the 800 mAh Li-Mi AAA batteries today and I inserted them in the handsets.
So far, so good.  I've used both handsets to make a couple of calls and then switched to speaker once connected.  Everything worked as it should and so this appears to have fixed the problem.  I'm just surprised the problem manifested itself on both handsets at the same time.
Thank you once again for taking the time to give me your advice.  It is appreciated.
Peter_W
Hey @JoRo1948, welcome back to the EE Community 😊
Are both of your handsets paired directly to your Hub?
Also if you head to http://192.168.1.254/ and select your landline, does it show both handsets as registered?
Peter
JoRo1948
Lesley_W
Thanks for the update @JoRo1948
This will no doubt help others that may experience the same issue.
Take care 🙂
Lesley
