Digital Voice issues
JonnyManc
Hi
Recently migrated from another isp for my fttp 500mb with digital Voice.
Fttp is working great, but having issues with maintaining digital Voice.
After a couple of weeks faffing, I got it sorted (registering phone etc) at it was ok, but this week callers can't hear me, nor can I hear them.... The phone rings and there is a dial tone.....
Any ideas guys?
222 REPLIES 222
Kielty1
@JimM11 totally agree, the web interface does everything I need it to. All the app does is cause issues..
Roger84
Valued Contributor
Valued Contributor
-----------------------------[Fault returns 01/10/24]-----------------------------------------------------------
Brief history of this.
I'm a BT customer who transferred to EE. I already had digital handsets with my Home Hub 2 in December last year and had a flawless digital voice service. This was with BT branded DV handsets.
Since the arrival of the BT Smart Hub, the digital voice service stops working. If I make or receive a call neither myself or the person on the other end can hear each other. A reset of the hub always clears the issue and it can be OK for a few days or a few weeks.
There is no pattern to the fault reoccurring and I have tried isolating handsets away from the hub to see if one handset not being in range or disconnecting from the hub causes the fault, but this is not the case.
There has been no fault at all with the broadband which has remained above the 700mb lower limit.
Things tried that have not worked:
  • I reboot the hub
  • EE reboots hub remotely
  • Factory reset of the hub
  • New EE handset
  • Replacement EE hub
  • Openreach engineer visit (even though the fibre connection is OK)
**There was never any problem with the BT branded equipment.**
Tonight the fault has returned and I have asked that it is elevated as a complaint. The gent I spoke to told me that this is a known issue, the first time that someone has acknowledged this to me on a call. This is quite concerning as the roll out of digital voice and the switch off of the copper land lines gathers pace.
I'll update on progress with the complaint when I hear back.
@Kielty1 I have posed question to EE DV to be forwarded to the specialist DV Team regarding this posting with your responses to have them take look. If/when i hear back will post asap.
@Roger84  You wrote "I'm a BT customer who transferred to EE. I already had digital handsets with my Home Hub 2 in December last year and had a flawless digital voice service. This was with BT branded DV handsets."  Do you mean BT Smarthub2?
"Since the arrival of the BT Smart Hub, the digital voice service stops working. If I make or receive a call neither myself or the person on the other end can hear each other. A reset of the hub always clears the issue and it can be OK for a few days or a few weeks."  Is this the EE Smarthub+?
All else is well known and documented throughout this section of the forum including the proposed FW updates to fix, rollout can be and is enforced by BT/OR now, but do keep the forum updated for sure.
UkzVortex98
Spend £10 amonth upgrade smart hub pro and fault goes away 12day my new hub hand no issue
A E KING
@UkzVortex98 Time scale still to short yet but you may be correct!
UkzVortex98
Smart Hub pro as been up for 2 week and no issue with Dv back to the smart hub 2 day
A E KING
@UkzVortex98 Thanks for replying back, good to know your DV is still working fine with the new Pro.
andydaws
Valued Contributor
Valued Contributor
Thought they had fixed on Super Hub Plus been several weeks I think then suddenly stopped again today requiring a reboot once finished work
@andydaws Did the re-boot of the router bring the DV back into full operation as far as you can see?
