Digital Home Phone Compatibility.
AdieUser
Hi all. We have recently availed ourselves of the EE Pay Per Call service when we purchased EE Broadband. I need to know what Digital Home Phones are out there for purchase that are compatible with the EE Smart Hub Plus. We purchased our package in-store & weren't asked if we need a phone. Our existing phone is a bit old and needs replacing. Help/suggestions/links appreciated. Many thanks.
Community Hero
Community Hero
@AdieUser Link below is BT phone range, any new dect based will also work, but you may not get all of the features, choice is up to you, phones will plug into back of router, or to remote adapter if you have that and the advanced connect directly with the router, no plugin required. EE DV is same as BT DV but not 100% like for like as yet read the forum there is a digital voice section with user input. Also download the call cost's so you are not shocked as pay per call is very expensive also. HTH
BT Home Phones | Corded & Cordless Phones | EE Store
Cheers! A 👍
