Digital Voice add on
Mattc77
Just want to know if I had EE Full Fibre installed, would I be able to add on Digital Voice and transfer a phone number over at a later date?  I'm currently with Virgin Media but will cancel at the end of the contract, which is end of November.  The WiFi is so crap I was thinking of getting Full Fibre installed before the VM contract runs out, but will need to transfer a phone number over later on.
Matt
Community Hero
Community Hero
@Mattc77 ? has there every been a OR supplied landline connection in your property before the VM Broadband/Landline contract that you have currently. Do not see any specific reason, but in some cases it is not possible to transfer a telephone number even at the start especially if it is a VM number. Would be a question best asked of EE CS regarding your request. Would be supplied as a DV connection (no choice on that especially on fttp) on the rear of the router, or via a remote DV adapter depending on what is best for you. HTH
