Condidering EE Digital Handset
JAMES45781
Whilst I have cordless phone which certainly should be compatible ,I am considering an EE Digital Handset as I believe it is a bit easier to set up.  However do not seem to be any on EE shop ,found this one on Amazon-I assume it would be ok.  https://www.amazon.co.uk/EE-Phone-Digital-Voice-Service-Black/dp/B0GBXSQGMW/ref=mp_s_a_1_2?dib=eyJ2I...
Still awaiting Engineer visit,  do you still need Adapter for this phone if using in room away from Hub?
No, the BT/EE Home Digital Phone has no cord to plug into an ATA adapter. It connects by DECT to a DECT base station built-in to the router. Therefore it should have similar range to ordinary DECT cordless handsets. These I find v. good. I can use them in the back garden from the base station in front of house.
@JAMES45781 wrote:
Whilst I have cordless phone which certainly should be compatible ,I am considering an EE Digital Handset as I believe it is a bit easier to set up.  ?
Any normal phone is easy to set up anyway. Just plug it into back of router or an ATA adapter remote from router.
7 REPLIES 7
JAMES45781
Just to confirm I will be receiving the Smart Hub 7 Plus.
Allright  thanks for confirming. Take it the Amazon one is fine  ,being upgraded to full Fibre and next Friday and just moving to EE.
Yes, it should be OK as it is advertised to "Works With BT And EE Digital Voice Service".
Yes thank you,I guess if you want to be wire free the Digital Home Phone is good. 🙂
l1feways
Landline in 2026🤣
It is more for an older family member 🙂
