15-05-2025 10:20 AM
How does one set up Alexa on EE HD Voice handset?
15-05-2025 02:24 PM
Thanks @RogerHale
There are two versions of this handset.
The BT/EE Advanced Digital Home Phone with Alexa, and the version you have which is BT/EE Essential Digital Home Phone with HD Calling without Alexa access.
To link your Alexa to your home phone, you'd need to use a BT Advanced Digital Home Phone with Alexa built-in
Ali
15-05-2025 01:07 PM
Hi @RogerHale
Which version EE HD Voice Handset do you have?
If it's the Advanced Digital Home Phone with Alexa built-in, you should be able to find the instructions on page 5 of the Digital HD Home Phone user manual.
Ali
15-05-2025 01:46 PM
Here is a picture of the handset I have. There does not appear to have an Alexa button on it.
please advise. Thanks.
15-05-2025 02:06 PM
@RogerHale
Are you able to provide the make/model? It should be written on a label on the main base station for the handsets.
Ali
15-05-2025 02:09 PM
15-05-2025 02:11 PM
Please advise
15-05-2025 02:24 PM
Thanks @RogerHale
Ali
15-05-2025 02:51 PM
Dear Ali_A,
is it possible to replace the Essentials handset with a built in Alexa handset?
roger
15-05-2025 03:15 PM
Is there a method of adding to the contact details on the handset by setting up a file on a PC and then transferring the file to the handsets?
15-05-2025 03:16 PM
@RogerHale
If you give our Customer Service team a call the guides will be able to check the options available for a different handset.
Ali
