on 27-09-2023 11:52 AM
So, if I take my phone abroad (S22), turn data roaming off, (and turn mobile data off as well maybe?) and connect just to WIFi abroad, can I a) avoid roaming costs
b) use WhatsApp back to UK (which is all I need really!)
and does wi fi calling need to be on or off?
I did use a roaming pass (£15) starting and stopping just for the one week I was away but had a kerfuffle with EE as they said the £15 was for full month useage even though I did it last year and it worked very well on a pro rata basis, this doesn't seem the case now PLUS it's increasing to £25 soon!!
TIA!
on 27-09-2023 12:24 PM
Disabling data roaming will simply stop you using mobile data whilst roaming. Charges could still be incurred for voice-call roaming & text-roaming.
Receiving texts is always free, but receiving a call is chargeable wherever you are. The only way to avoid all roaming charges is to not roam - which means not connecting to any foreign network.
WiFi-calling is not officially supported abroad, but if it does work then roaming charges also apply.
on 27-09-2023 09:48 PM
Previously you may have had the Roam Further Pass which was pro-rated at both the starting & ending billing month. The Roam Abroad Pass doesn't do that.
