Roaming call to own number
deanbi
Hi, recently abroad and looking now at itemised roaming calls it shows me calls to my own number! I haven't called myself and haven't used voicemail so it's definitely not that. Can anyone explain this?
7 REPLIES 7
@deanbi : Somebody called you while abroad & left a VM. As you haven't used VM you haven't seen it.
deanbi
No, definitely not that. One shows as a call to own number that is 45 minutes long!
Katie_J
Hello @deanbi.
Did you receive any calls from UK numbers whilst abroad on the dates and times showing?
Katie
Does your phone's call log show any other calls that tally with the date & time, allowing for time differences?
Yes, I guess so. Can I tell what number was incoming though?
Katie_J
If your incoming call has been recorded on your bill as your number with being abroad there is no way to change this @deanbi.
Katie
If you can tally the bill entry with an incoming roaming call on your phone's call log,then the log should show the number that made the call.
