23-01-2025 08:03 PM
Please can I reduce my total amount to £15 a month as no longer use this sim
23-01-2025 08:12 PM
If you're outside your minimum-term, you can change your priceplan via your myEE online account.
If you're within your minimum-term, you will need to complete that first.
Whether you're using the SIM is immaterial in either case.
23-01-2025 08:12 PM
