on
22-09-2024
05:17 PM
- last edited on
22-09-2024
06:03 PM
MikeT
Good afternoon does anyone know how to get a copy of my call history
Solved! Go to Solution.
on 22-09-2024 05:25 PM
If you had itemised billing active at the time, then that shows your calls.
Otherwise, your phone's call logs holds your call history.
on 14-12-2024 07:19 PM
How do you get a historic list from last year, bills are not itemised?
on 15-12-2024 03:13 PM
Hi @TaylorNJT
Welocme to the Community!
We won't keep a record of your call history if you haven't requested itemised receipts, but if you request this then this will be done moving forward.
Rach
