on 24-02-2025 05:29 PM
I am abroad to study since September 2024 and I will be back in September in London.
How can I suspend moving forward my plan and restart in September.
Many thanks,
Raphael
24-02-2025 05:39 PM - edited 24-02-2025 05:40 PM
Contracts can't be suspended but you may cancel it with 30 days notice & request it be moved to PAYG so as to keep your no.
on 25-02-2025 10:51 AM
@Raph04 , just to add, if you request to move to pay as you goo, you first need to activate and use the SIM card in the UK for it to work abroad.
on 25-02-2025 01:33 PM
@Raph04 If you do terminate you also have to pay off the remaining term of that contract. And as @Schockwave says it’ll not work if you’re outside the UK should you make request also to change to PAYG.
