03-10-2023 12:43 AM
Anyone know when they stop charging you , I added air pod pro max and I’m sure I’ve paid for these but still getting charged
03-10-2023 03:11 AM
Hi there, you can check your add to plan accessories by looking at add ons on the My EE app, there it will give you the end date for your add to plan. Alternatively you can call EE on 150 from an EE number to check your add to plan and look at options to remove/pay off early
Hope This Helps
03-10-2023 03:11 AM
Hope This Helps
