on 06-08-2024 11:43 AM
i have moved from bt to ee boardband, have a new hub but want to keep my old password as everything is connected to it . is this possible
on 06-08-2024 01:19 PM
Yes. Which router do you have?
on 06-08-2024 04:41 PM
Yes you just need to go into WIFI settings on the EE router and change the network ID (SSID) and Password to match those of your existing router
