wifi disconnecting randomly
xskc
Hey any ideas on why my wifi just cuts out randomly then turns back on ive been playing my playstation wifis been great then randomly out of no where it just cuts out done it a few times now really annoying
7 REPLIES 7
@xskc : Which EE BB plan are you on including its speed? What EE router do you have (read its label or post a pix)?
Northerner
Hi @xskc
PS5 or PS5 Pro?
You should go out nto your PS5 network settings and change the connection to only connect to the 5ghz as this will strengthen the connection as I suspect it will be connecting to 2.4ghz.
Ps5
The EE Smart Hub Plus  WiFi 6 router
The EE Smart Hub Plus is a wifi 6 router
Yeah it still cuts off
Rach_H
Hi @xskc
Welcome to the Community!
Can I just check if your WiFi is also dropping on other devices, or if this only seems to be affecting your Playstation?
Rach
