07-03-2026
06:31 PM
- last edited on
07-03-2026
08:33 PM
Kh_timi
I’m a BT customer and use their broadband. However, I’m concerned about post January ‘27. Getting Full Fibre is a no go due to connection logistics. What’s going to happen re our access to broadband should we not have made the switch to Full Fibre?
[Mod edit: Title added]
07-03-2026 06:56 PM - edited 07-03-2026 07:05 PM
@RGC3 : You'll be put on something called Single order Generic Ethernet Access (SoGEA). It’s a replacement for Fibre to the Cabinet (FTTC). It uses existing copper phone lines, as yours does now, but does not require an active phone service. It runs with the same speeds as FTTC. You may already be on it.
Do you currently have an active landline?
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
07-03-2026 08:28 PM
Yes, I do have an active landline. The reason for my enquiry is that a neighbour has the same logistical problem re connection to full fibre. He was given an ‘EE 5G mini hub which he uses for everything. What advantage would I have with the mini hub?
07-03-2026 09:03 PM
Not a lot! Mobile signals are rather unreliable & variable. Fixed BB is usually rock solid.
When you are moved to SoGEA for Jan. '27 your landline would go Digital Voice (DV) if you still want it.
07-03-2026 09:13 PM - edited 07-03-2026 09:32 PM
@RGC3 What is it that you have currently on your BT Package, take a look at that.
07-03-2026 09:24 PM
SOGEA is still FTCC, it just does not have a PSTN Voice component. Digital Voice is the BT/EE Brand name for their VOIP service, but you are free to select your own VOIP supplier with SOGE or Full Fibre.
HTH
07-03-2026 09:37 PM
@Mustrum : Yes, I know but everything on BT seems to speak as if it's diff. e.g.:
Simplify with Single order Generic Ethernet Access
Say hello to Single order Generic Ethernet Access (SoGEA). It’s a replacement for Fibre to the Cabinet (FTTC) orders
07-03-2026 09:40 PM
@XRaySpeX Still delivered the same way new name and dropped the fttc name from the spec.
07-03-2026 09:41 PM
@JimM11 : Obviously!
07-03-2026 09:44 PM
Thanks to all. Your responses are reassuring.
