21-01-2022 06:56 PM
My phone and tv keep coming up with cant authenticate connection so im unable to watch my freeview or use wifi on my mobile
21-01-2022 07:05 PM
Which router?
21-01-2022 07:11 PM
I think its the bright box 1
21-01-2022 07:16 PM
Are you supplying the TV & mobile with the BrightBox 1's WiFi pwd?
21-01-2022 07:21 PM
Yeah password is being used for tv and phone wifi
21-01-2022 10:42 PM
Hi @Rachel120692 ,
Has everything worked ok in the past and this is a recent problem which has occurred?
Has there been any recent change or new addition that may have caused this?
As a sanity check, are you able to Ethernet cable a device to the LAN ports to bypass the WiFi password and see that internet works ok?
