Bizarre issue with new hub and Discord
Zozzilla
As the title says, I'm having a very odd issue with my new Smart Hub Plus after previously using a BT Smart Hub 2. When using Discord, specifically the PC app over ethernet, I am unable to upload images or stream to friends without the connection almost grinding to a halt.
The issue doesn't happen if I use the Web browser version of Discord, or if I use WiFi on my laptop or phone. I did a speedtest using Ookla and everything was fine for both wired and wireless, however if I use Cloudflare's speedtest, the wired connection hits about 40mbps download and 17mbps upload with at least 10% packet loss.
I never had this issue before yesterday when I got the EE Smart Hub Plus plugged in, and was wondering if anyone else had a similar issue and knew of a way to fix it? I tried using Google DNS instead and that just made the whole connection run at a tenth of its normal speed.
OF1970
Hi there,
I had the same issue with discord after switching to EE, using a VPN fixed the problem for me
6 REPLIES 6
Northerner
Hi @Zozzilla
Have you any family/content lock in place.
Nope, nothing at all. I've been checking everything  over again for the past hour, testing different things, and it's definitely only affecting my laptop for some reason - other devices aren't having the issue (I tested it using my phone and my work pc)
It's only affecting Cloudflare specifically, nothing is blocked when I log into the router, I've not changed any settings on my laptop at all, I've tried updating the drivers for both the ethernet port and the WiFi adapter so I'm not sure if it's an issue with the IP address assigned to it or not.
I've just plugged my old router back in, and there's no issue with this one plugged in, so all I can think is that there's some sort of security on the new hub blocking just that specifically...but trying to figure out what it is is going to be hard.
OF1970
Hi there,
AnnoyedEEUser1
Hi, I have this issue too and EE is completely ignoring it.
Linzi_H
Hi @AnnoyedEEUser1
Have you been in touch with our team previously about the issues you're facing? If so, what has the team said?
Have you tried the solution within this thread?
Speak soon,
Linzi
If the Discord desktop app tries prioritising traffic (which a quick Google search suggests it may), then it could be related to this?
