15-01-2025 08:26 PM
I am trying to find the password for my hybrid connect hc10a. I am using the app to set it up
15-01-2025 08:30 PM
@Pandapurr1 See if anything from the help below is any good, no idea what a hc10a is.
https://ee.co.uk/help/broadband/getting-started/hybrid-connect-set-up
https://ee.co.uk/help/broadband/fix-problem/fix-smart-hybrid-connect-broadband-problems
15-01-2025 08:35 PM
@Pandapurr1 the only password involved os the WiFi one when you connect it to your router, this will be on the little card on the back of the router.
Or you could just use WPS.
More info in the Help Page https://ee.co.uk/help/broadband/getting-started/hybrid-connect-set-up#article-heading-1
16-01-2025 01:33 AM
Thanks for the help. Much appreciated
