slow up load speed
1ginge
iv just bought a tp-link wireless router on ee and the up load speeds are nearly non-existent, advise please
Mustrum
@1ginge  which router have you bought, and which EE service do you have?
How are you testing the speeds?
I’m testing by 3 different systems, 2 different apps and the manufactures app
Regards
Andrew
Sent from my iPhone
Mustrum
@1ginge  that really does not help anyone know what router you have or the service you are connected to.
Alas my mind reading is not up to figuring what kit or service you have!
