problems with my BT 4600 phone/answer machine
reghorlock
Hello,
I've been having problems with my BT 4600 phone/answer machine. I've just switched over to EE and Digital voice.
Basically, I've asked them to increase the number of rings on the EE 1571 voicemail to 10, and I've set my BT4600 answer machine to 8 rings. Sometimes it works and takes a message, then other times it cuts in and just hangs up the call.
Does anyone know why this would happen?
Thanks for your time
Reg
[Mod edit: add title]
22 REPLIES 22
Conrad1961
Skilled Contributor
Skilled Contributor
@reghorlock   When you say "it cuts in and just hangs up" are you referring to the answer machine or 1571.  The cutting in could be because it is a spam call hanging up so no message is left.
Maestro
Maestro
@Conrad1961 Check that the system is getting the full 10 rings by switching off the answering machine, you may just find that 8 is close to answering the call every time as well.
Conrad1961
Skilled Contributor
Skilled Contributor
@JimM11   Yeah I was thinking about telling @reghorlock  to reduce the 4600 to 7 rings like I have on my phone just in case 1571 was too close especially with DV.
reghorlock
Thanks for your replies. Yes, I mean the answer machine cuts in and hangs up.
I tested 5 times. Basically, 3 out of 5, the answer machine picked up and took the message correctly. However, 2 out of 5, the answer machine cut in but just hung up the call (without taking a message).
I could lower the rings 7 to see if this helps.
Someone also mentioned it might be related to the Call Protect service, and someone also mentioned resetting the BT4600 phone/answerphone?
Conrad1961
Skilled Contributor
Skilled Contributor
Do you what numbers have called when the answer machine cuts in as I usually never answer an unknown caller and let it go to my BT Graphite where no message is left because it is a spam call. My phone requests a message is left but the caller immediately disconnects which means nothing is logged as a message only as a missed call.
I've just been testing using my own mobile number.
Are you suggesting that it might be related to some sort of built-in spam call function either on the line (EE) or on the BT4600 phone itself? e.g., if the same number calls too many times, it hangs up and doesn't allow them to leave a message on the bt4600 answer phone.
@reghorlock Will be on the EE side off the digital voice, the systems all use calling spam filters etc...
EE's Call Protect (1572) doesn't block calls unless you ask it to block certain calls. Otherwise it lets suspected spam calls thro' with the Caller ID showing as "Nuisance ?".
Thanks for your reply. Right ok.
So if it's not any sort of Call Protect or EE line issue, then it must be the BT4600 answerphone itself.
Calls are coming through, but the BT4600 answer phone picks up and hangs up the call.
Someone suggested resetting the base and handset so I'll try that.
Also, someone else suggested removing the filter in the phone socket (which the router is plugged into). However, I was under the impression that you still need a phone line splitter when it's a single wall socket?
Thanks for your help so far!
