27-04-2026 08:03 PM
I am very curious, last September I received an email containing the following
Since when I have heard nothing , has anyone else had a similar experience or can explain what is going on?
27-04-2026 08:40 PM
Looks like they wanted to move you, for free, from legacy BB to New EE BB, perhaps even Full Fibre, but have not implemented it yet.
What is the name of the EE BB plan you are on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
What does BT Wholesale Broadband Availability Checker > Address Checker estimate for your address? Post the whole table, the text below it and the line above it, blanking out your address.
29-04-2026 09:36 AM
Sadly I can only tell you the plan name the Availability checker does not respond to address or telephone number! The plan is Fibre and Broadband with landline. A misleading title since I do not have direct fibre. I believe the speed is of the order of 30Mbps. the router is an EE smart router.
29-04-2026 04:58 PM
Thanks, @StuartC4.
Most of our contracts now will utilise some form of fibre - either fibre to the cabinet which is still delivered through a traditional BT socket, or fibre to the property which uses a fibre connection direct to your house via a small modem called an ONT.
The latter of these are on what we call 'Full Fibre' plans.
From what you've shared here it sounds like this is just an internal update and replacement Hub like @XRaySpeX recommended rather than a switch to Full Fibre.
But so we can say with absolute certainty what's happening here, I'd recommend giving our team a call and they can help check everything at our end.
Peter
