07-12-2023 04:02 PM
Hi, I have recently moved from BT to EE digital home phone. At the moment I am using my BT phones with an adapter supplied by EE to connect to the hub. However, I would much prefer to use new phones that connect directly to the Hub. I am not sure what to buy and have searched the EE site for such phones (are they VOIP phones?) and cannot find them.
Can someone at EE advise please
07-12-2023 07:18 PM - edited 07-12-2023 07:24 PM
See the following links to the EE Store for the Essential and Advance phones:
https://store.ee.co.uk/products/bt-essential-digital-home-phone-090709-G4Z9.html?q=Digital%20voice&s...
https://store.ee.co.uk/products/bt-advanced-digital-home-phone-with-alexa-built-in-101806-G9YX.html?...
The details say for BT Digital Voice but they work on EE Digital Home Phone.
08-12-2023 09:18 AM
Hi, that's great, many thanks
Paul
08-12-2023 09:21 AM
Hi
do you know if you can import contacts into the phone. I could link via bluetooth to my mobile with my BT phone and import. I could not see this feature in the mangal
Paul
08-12-2023 04:53 PM - edited 08-12-2023 04:58 PM
@heelisp Try this on the BT community. There are others if you do a search for "import contact details into digital voice".
Once you've imported them there is an option to Export. I suggest that you create an export after the import and when you add new contacts as if you do a hub reset or get a replacement hub you will have lost your contacts as they are stored on the hub.
31-03-2025 02:34 PM
I can’t actually answer that but any local numbers you have in your phone you will have to add the dialling to.
02-10-2026 01:46 PM
For anyone else who finds this thread looking for handsets... The EE shop linked on this page charges £44.99 as of writing. You can get them from Amazon for £19.99.... Also just checked eBay, they're going for about £12.50 - £12.99 + [£3.99 ish P&P] NEW boxed, multiple sellers. Much cheaper.
