home wife keeps dropping
Smee60
Sick to death of my home broadband dropping. It is so random. It could go off for 1 to 10 minutes at a time. Every time I do a service check through mobile app my internet comes back. It's a real pain. I can't report it as it is just so random.
Mustrum
@Smee60   of course you can report it. The broadband care will be able to see if it is happening on a regular basis and get someone out to sort your line.
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
Support for Deaf and hard of hearing customers
Text relay
To use the text relay service from your smartphone, PC or tablet, download the free Relay UK app.
To call us through the Relay UK app or from a textphone, dial:
18001 07953 966 150
Sign language services
If you need the support of a British Sign Language (BSL) interpreter, you can contact us through the InterpretersLive! service.
Connect to a BSL interpreter
Which EE BB plan are you on including its speed? What EE router & WiFi extenders do you have (read label or post a pix)?
Just on normal home Internet. It's roughly 30 meg
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
