on 03-02-2025 06:17 PM
i have currently upgraded from ee full fibre smart wifi to ee smart hub pro. it goes live fri and had my equipment delivered today. i tried setting hub up with ee home app as recommended. but when i use app with camera at back of new hub it dont recognise the hub. im not sure if i need to wait til fri but i can connect manually with password etc but the app dont.
just wondered if anyone knew or had same problem
thank you in advance
Solved! Go to Solution.
on 03-02-2025 07:36 PM
The EE Home app doesn't work with the EE SH Plus/Pro. It is intended for the white EE Smart Router. You need the EE App.
on 03-02-2025 06:48 PM
@dags9475 The EE HOME app is non functional, you NEED to use the other app. Link below.
EE app release (Android) EE: Game, Home, Work & Learn - The EE Community
on 03-02-2025 08:17 PM
When I tried the new app I got the same problem. I couldn't get it to work either neither on scanning nor putting the details in directly - If you do manage to get it working please do let me know how?
on 03-02-2025 09:35 PM
i know what you mean the app shows new hub and follow instructions but when you click that aqua colour showing it scans for the hub but dont do anything but searching
on 01-05-2025 02:45 PM
New EE Smart Hub Plus & latest EE APP early April 2025 - have the same problem ...
Anybody found a solution please ?
on 01-05-2025 06:20 PM
Hi @SpeedTrip.
Welcome to the Community 😊
Just to be sure, has your connection gone live yet, or are you waiting on this soon?
Also what exactly happens when you try to set this up?
Peter
on 02-05-2025 06:51 AM
Yes, it went live in early April. I've been using it overall successfully ever since ...
I wanted to try the EE APP to setup Hub's Wifi options, but as others in this thread have said, when you use the SCAN option to start configuring, the APP just 'spins' and doesnt progress to the setup expected. Enter details manually doesnt work either
on 02-05-2025 08:41 AM
@SpeedTrip Is all that you try to do via the web manager interface working as you expect?
on 02-05-2025 08:49 AM
Yes- saw no other options - presumably would progress if the Pairing with the Hub was successful. Otherwise the only use I have for the App is to check Bills .. which is quite clunky too !
