ee broadband
martyn1001
Does the EE router supports the following DDNS service provider: No-IP or NOIP
Christopher_G
Hi @martyn1001
Welcome to the community.
Is it a mobile router or a fixed line router that you're using?
It's a modemSent from my Galaxy
pip11
Scholarly Contributor
A modem neither knows nor cares about DDNS.
James_B
EE Community Manager
Hi @martyn1001,
Which EE router are you using?
You may call it a Modem, but it will actually be a Modem Router. Just which 1?
Both the EE BrightBox & the EE Smart Hub support NoIP.com.
