digital phone number
MRc1962
Hi I moved to ee just over two month I asked to keep my original phone number when i changed from Talk Talk and when i changed they changed the number i have had people telling me they cant get hold of me how do i get the number changed to my original number that i asked for .
MRc1962
Thanks JimM11  I called into the ee Shop today and used there phone and got it sorted due to the fact my old provider said i could keep the number when i left them, should Have my old number back on in a couple of days .
Maestro
Maestro
@MRc1962 You would have to call EE CS to discuss that but after 2 months it may just no longer be available for you to get, you should try calling it to see if someone picks up, if not you may be able to find out if EE will do anything, think they will say NO!
MRc1962
@MRc1962 Good result and the perfect ending well done you!
