12-07-2022 04:00 PM
I currently have EE fibreplus and during any Microsoft Zoom call when using the Screen-share function, I get the “unstable connection” or low connectivity message.
The app reports packet loss due to low bandwidth.
The issue is present when using both a wired or wireless connection.
The company IT department state that the internet service provider needs to increase the bandwidth for the Zoom application on the firewall.
Anyone experienced the same?
Recently two BT Openreach Engineers have visited the property and have inspected the wiring to be ok. The downloads speed i get are above 40mb and the upload 15mb.
12-07-2022 04:07 PM
Do you mean Microsoft Teams or Zoom? They are diff products. MS Team is far more extravagant than Zoom.
13-07-2022 07:52 AM
The issue is with Microsoft Zoom.
13-07-2022 08:05 AM
13-07-2022 08:05 AM
13-07-2022 08:05 AM
13-07-2022 08:34 AM
@Christopher_G @XRaySpeX Are the details visible to you?
13-07-2022 09:02 AM
Yes, that's good. & part 3. please.
There is no Microsoft Zoom. It's either Microsoft Teams or Zoom's Zoom.
13-07-2022 09:36 AM
It is Zoom.
Apologies I thought Zoom was owned by Microsoft.
13-07-2022 09:44 AM - edited 13-07-2022 09:45 AM
Thanks, everything looks good there. You should not have any issues using Zoom. I have no issues using Zoom's Screen-Share function on a much lower bandwidth.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
