17-05-2022 07:09 PM
Hello,
As with most people these days, I am a big MS Teams user working from home Monday to Friday. When I am on a MS Teams call with my camera on, I am constantly being told that my camera has froze and I result to having to switch the camera off.
I would like to know whether there is anything I can do to ensure I am getting the best service from my EE Router.
I have the router downstairs and it is wirelessly connected to a Wireless hub in my office which my 2 laptops are wired into.
Can anyone suggest anything please?
Greg
17-05-2022 07:42 PM
Hi @gregharper and welcome to the forum.
The way to get the best from your router would be to have your pc/laptop connected directly - to determine if it is wireless or your extender that is causing your problems.
Sight of your router stats, and the results from the BTW DSL checker will show if your line is up to a speed to make Teams calls. https://www.broadbandchecker.btwholesale.com/#/ADSL
17-05-2022 07:46 PM
Hi @gregharper
In real terms you need a powerline adaptor kit to your office hub from your router ethernet port, or disable WiFi on your router and get a better WiFi access point. Your weakness is the WiFi on your free router. Just search the forums as it seems to be ok (occasionally) but most people have some issues especially with demanding applications such as teams.
WiFi from the "free" routers isps give away is always rubbish.
I'm with Sky and I have 1200 Netgear powerline adaptor kit to my WiFi access point. I use teams on a tablet (on a camera stand) and is works a treat. If you work at home investing in better kit pays off especially when using numerous devices.
